hamtickell
Jun 10, 2018Aspirant
Orbi disconnecting on Cox modem Arris SB8200
Bought the Orbi in 2017 and set it up in October 2017. Now it is June 2018 and for the past month I have been experiencing frequent disconnects from the internet. Can be resolved by reseting Orbi ...
Jun 18, 2018Guru - Experienced User
Ok, see if the setting of manual channel helps any. You maybe in a wifi congested area.
One thing you can do is to set the power on the radios from 100 to 75% and see if this helps any as well. You'll have to move any satellites a bit closer if you do this as the range will be reduce by the change...
