SupahFox
Apr 28, 2021Tutor
Orbi disconnects after ip change
So, my ISP by default changes the IP address every 6 hours and orbi disconnects for 1 minute aprox. I contacted my ISP and it said that it was the orbi router. Pls help Firmware: RBR20 V2.6.2.104 ...
Apr 28, 2021Guru - Experienced User
Wow, who is your ISP?
You might try this:
SupahFox
Apr 28, 2021Tutor
Antel, the only ISP here in Uruguay. In 2022 we'll have Starlink lol
- LlamaLarryApr 28, 2021Luminary
That's a crazy short lease time, but you have to work with what you get.
You can go to Advanced -> Internet Port -> Connection Status in the Orbi UI and Release then Renew when your ISP refreshes your IP. This will be faster than waiting for the Orbi to do it by itself.
