SupahFox
Apr 28, 2021Tutor
Orbi disconnects after ip change
So, my ISP by default changes the IP address every 6 hours and orbi disconnects for 1 minute aprox. I contacted my ISP and it said that it was the orbi router. Pls help Firmware: RBR20 V2.6.2.104 ...
CrimpOn
Apr 28, 2021Guru - Experienced User
SupahFox wrote:So, my ISP by default changes the IP address every 6 hours and orbi disconnects for 1 minute aprox. I contacted my ISP and it said that it was the orbi router. Pls help
(the modem is configured in bridge mode and orbi in router mode)
On the Orbi web interface, Advanced Tab, the blue box labelled "Connection Status" will display the lease that was obtained and the time remaining. Typical DHCP practice is for the client to begin attempting to renew the lease when it is half expired. If the lease provided was for six hours, there should always be more than three hours remaining because the Orbi will renew for another six hours at the three hour mark. It would be useful to know when the ISP issues a different IP address.(Is it during a regular renewal? Just "out of the blue" in the middle of a lease period?) It is actually a different IP address every time?
This may be a situation where the modem should not be in bridge mode. (Lessor of two evils: give up some applications like port forwarding, VPN, etc. vs. suffer 1 minute outages every six hours)
I had never considered what changing client IP addresses would do to every TCP connection that has been established. Every data packet that arrives at the ISP for this IP address now has to go ..... where?
