hobbnet
Aug 08, 2017Tutor
Orbi Disconnects for a split second every 5 - 10 minutes.
I've seen a lot of different complaints about this issue but I haven't seen any fixes. My firmware is up to date and I've done a factory reset. I called netgear support last night and the rep I ...
st_shaw
Aug 10, 2017Master
hobbnetHow are you detecting these split-second disconnects? What impact do they have on your devices or applications?
- This2ShallPassAug 10, 2017Tutor
I know the question is directed to the original author, but it messes with my work laptop (gov't issue) VPN, and it slows the ability for page loading on smartphones. Occasionally, the smartphone just hangs in mid-progress bar. Not technical enough to know for sure, but I assumed the handoff from wifi connection to data and back again can stall the page loading.
Kinda frustrating.
