Bluegrass1908
Jan 26, 2018Guide
Orbi disconnects from internet intermittently
I bought an Orbi system with two satellites (RBR40). The Orbi disconnects from the internet every so often and, after a while, reconnects. Here's what I figured out already: 1) It's definitely th...
Bluegrass1908
Jan 30, 2018Guide
Hi -thanks. Answers below:
Have you tried a manual update to the satellite by plugging a pc directly into it?
The satellite isn't the problem, the central Orbi router is the problem (I've tried in WAP mode and regular router mode, same problem persists). The satellites are working fine. If you're asking whether I have anything plugged into the ethernet ports of the Orbi router - the answer is yes (Philips Hue). Those devices work when the Orbi is offline. So again, we have connectivity to the Orbi itself, but the Orbi is offline for internet purposes.
Do you have your comcast modem bridged or modem only? Have you tried to factory reset the orbi unit?
I'm using an Arris modem. I've factory reset the orbi probably a dozen times now.
Thanks for your help. Is there a number I can call? The last number I called, that I thought was a Netgear service number, was not effective.
DarrenM
Jan 31, 2018Sr. NETGEAR Moderator
- Bluegrass1908Feb 20, 2018Guide
Problem still not solved and from a quick Google search, it seems thousands of customers are having the same problem. After hours of trying to get the actual phone number of Orbi support, I spent even more hours on the phone with Orbi support, who troubleshooted our way to nowhere. Now they are exchanging the physical router unit to make sure it's not a hardware problem, and after that, they are going to send me to the engineers to see if they can create firmware to solve the issue. Not very inspiring since so many are having this same problem and Netgear cannot create firmware that solves it. Good luck to anyone else having this issue - if you're within your return window, RUN DO NOT WALK to your retailer and switch out the Orbi for literally any other mesh network system.
Should the problem ever be solved I will return and update as needed.
- tsigFeb 20, 2018Luminary
Doubtful. Frustrating for you for sure, but no way there are "thousands" of customers having this issue. I don't there are "thousands" of Orbi systems deployed.
lol ok. Netgear must have fallen on hard times if sales of its mesh network system have not reached four digits yet.
- esemartinez311Feb 16, 2019InitiateDarrenM: Your credibility really disintegrates when I click on the link while on my Orbi wifi and it takes me to a 404 error page, then I turn my wifi off to use cell data and the page no longer exists.
Orbi disconnects on all of my devices on wifi but everything hard wired doesn’t. There goes my $$$. Switching to the google version.- FURRYe38Feb 16, 2019Guru - Experienced User
The link is working for me.
https://www.netgear.com/support/contact.aspx
There are others with good working Orbi systems. Maybe if you gave a bit more information, maybe can help you get your Orbi working.:
Is the Orbi system operating in Router or AP mode?What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enableding Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Orbi disconnects on all of my devices on wifi but everything hard wired doesn’t. There goes my $$$. Switching to the google version.- Chuck_MFeb 17, 2019Mentor
esemartinez311 -- Sounds to me like you have a configuration issue -- that folks here probably can help you solve.
Before you throw the baby out with the bathwater and get another router -- which will probably have the same configuration issues -- do you want help?
If so, recommend you start a new thread with your issues and configuration (including make and model of cable modem).
