Bluegrass1908
Jan 26, 2018Guide
Orbi disconnects from internet intermittently
I bought an Orbi system with two satellites (RBR40). The Orbi disconnects from the internet every so often and, after a while, reconnects. Here's what I figured out already: 1) It's definitely th...
Sep 20, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be aware of your ISP modem:
CEaton12 wrote:
Add me to the list of long suffering Orbi owners. I am the same issue that others are reporting....wireless devices system wide will randomly lose internet access, hardwired devices to the base will be fine, I need to reboot the router and satellites each time. I have tried a huge number of things, these must be known to Netgear....just needs to be fixed.
This is what I do for a living, I have comcast business and I'm using an Arris 32 x 8 Docsis 3.0 (SB6190) modem, everything is set up properly, still getting internet drops a few times a day. I live in a connected home which relies on reliable internet.
When is this going to be fixed?
rnorthway
Sep 20, 2018Tutor
I finally gave up on Orbi and returned it to Costco. I then purchased a 4 node Velop system from Costco and it's been rock solid. So glad I dumped Orbi and all the frustration. Good luck.
