Bluegrass1908
Jan 26, 2018Guide
Orbi disconnects from internet intermittently
I bought an Orbi system with two satellites (RBR40). The Orbi disconnects from the internet every so often and, after a while, reconnects. Here's what I figured out already: 1) It's definitely th...
WernerDT
Dec 23, 2018Initiate
Thanks for the link:
https://windsorwebdeveloper.com/making-netgear-orbi-great-again/
This solved my LG UHD TV issue as seen here:
https://lgcommunity.us.com/discussion/437/lg-smart-tv-wifi-wont-turn-on
The LG "error" message doesn't really make you think its related to the router, which made it quite difficult to troubleshoot.
Dec 24, 2018Guru - Experienced User
Thanks for posting this. Seems like this is a TV issue for those with this particular brand of TV.
