Bluegrass1908
Jan 26, 2018Guide
Orbi disconnects from internet intermittently
I bought an Orbi system with two satellites (RBR40). The Orbi disconnects from the internet every so often and, after a while, reconnects. Here's what I figured out already: 1) It's definitely th...
0703kb
May 02, 2019Star
5 days with no drop outs at all. A full reset of Router and Satellite appears to have solved my problem.
Definately worth doing if you are getting the dropouts.
May 02, 2019Guru - Experienced User
Great to hear. Glad it's working now for you. Others have expressed that same thing. Resets maybe needed.
Be sure to do a backup of the config to file for safe keeping. Helps save time if another reset is needed.
Enjoy. :smileywink:
