BUCK68's avatar
BUCK68
Follower
Feb 25, 2018
ORBI DISCONNECTS SEVERAL TIMES PER DAY --- DOS ATTACKS
Not sure if this is DOS attack related but I've experienced ongoing problems with dropping connection for the past month (maybe since the last update?) when I scan the log it shows im being hit with numeorus DOS attacks continuously.  The DOS attacks, I suspect, are causing dropped connection.  Anyone have a fix for this?
1 Reply
  • FURRYe38's avatar
    What modem Mfr and model# are you using?
    Cable or DSL?
    Where are you seeing these DOS attacks?
    Is the disconnects seen on the client side or router side? WIreless disconnects?
