jacoblee16
Jul 16, 2020Aspirant
ORBI disconnects temporarily when i go upstairs
I have the Orbi, 2 satellites. My connection temporarily disconnects when I go upstairs. For mesh routers, I should have a continuous connection correct? I have noticed my connection go out when I am...
CrimpOn
Jul 17, 2020Guru - Experienced User
jacoblee16 wrote:Disabled: Fast Roaming, Daisy chain - I noticed frequent disconnects when I had these enabled. Is this why it's not constant?
Daisy Chain should have no effect on this. If you notice that both satellites connect directly to the router, then disabling Daisy Chain makes sense.
Fast Roaming is intended for this situation, where a device moves from one Orbi device to another. I have it set "on".
