r0b0tvampire
Mar 16, 2021Star
Orbi DNS and DHCP and NTP Broken
You can see many people on this community as well as Reddit: https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/ posting about their problems relating to recently losing Internet conne...
Blanca_O
Mar 24, 2021NETGEAR Employee Retired
Hi Orbi Community,
Engineering was able to discover the cause of this issue and they are working on a fix in regards to the disconnections.
The issue comes from Traffic meter while daylight saving is enabled. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
We appreciate all your cooperation and patience working with us. We will provide update once we have the fix firmware.
Blanca
Community Team
Blanca_O
Apr 05, 2021NETGEAR Employee Retired
Hi Orbi Community,
In our engineers investigation, the cause is identified as the incorrect behavior on traffic meter which will constantly do some setting on router DNS while daylight saving is turned on. And this could possibly make the DNS query unstable.
Workaround solution: Turn off traffic meter.
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck "Traffic Meter"
Fix firmware is now available to resolve the issue even if the traffic meter is enabled. Kindly let me know or send me a private message by clicking this link if you would like to test it.
Blanca
Community Team
- vajimApr 05, 2021Master
Blanca_O wrote:Hi Orbi Community,
Blanca
Community Team
What's the version number of this 'fix'?
