namrevil71
Jul 04, 2018Guide
Orbi DNS communication issues
Browse NETGEAR ® COMMUNITY United States General WiFi Routers Log In Join Now namrevil71 namrevil71 Aspirant Aspirant 2018-07-03 12:19 PM Orbi Pro router not communicating with physi...
Jul 04, 2018Guru - Experienced User
Even though you set up different DNS IP addresses, DNS Relay proxy on NG routers is in effect thus all connected devices will get a 192.168.1.1 IP address for there DNS. There is no way to disable this DNS proxy on NG routers.
I see you may have a Orbi Pro, something that should be posted here:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
As the Pro differs in FW and software. Maybe the Pro version can support disabling of DNS Proxying. You'll need to ask there.
