mtlam
Nov 29, 2017Guide
Orbi DNS Disconnecting
Hi everyone,
I'm already in contact with support about this issue but wanted to see if you guys could give me some input on my current issue.
So this issue occurs on the satellite units whether I have the router in AP or router mode it still affects it. Everytime I use torrents, it causes the DNS to crash and renders the satellite unable to connect to the network but is still connected to the Orbi Router. The router itself doesn't have any issues I can browse the net etc. For the satellite units, I need to turn it on and off or change a setting that would reset the backhaul connection for the satellite to work again.
This is all on the latest firmware.
Hoping you guys could give some input thanks!
Are you handling your torrents on your local computer or a NAS, etc? Is the torrent program set to use a specific DNS server and/or assigned IP by a any chance that may come in conflict with the satellite?
Else, the classic factory reset of all your networking products might do the trick (external router, included).
Also, check for MAC-adress clones in your network (rare, but it happens).
- mtlamGuide
The torrents are being handled on a local computer connected to the satellite. I've tried utorrent and qbittorrent to rule out client specific issues and settings wise, I do not specify a dns for the clients to use. I've checked the client list and attached devices list to see if there is a conflict in IP but there is none.
Yeah I've done that several times and even rolled back firmware on the units to rule out if a specific update was causing this.
No MAC-Address clones in my network either.
One thing though, when both satellite lose connection after starting a torrent if I turn one of the satellite off the other will come back up.
- On your main router that is handling the routing/DHCP, reserve IP addresses for your satellites.
Turn off your routers wifi (with Orbi router in AP-mode).
Make sure MU-MIMO and beaming is turned off.
Also, is your router well-placed? What lastly did the trick for me and my Orbi troubles was placing the router in the center of the house, away from any concrete walls (had it in my living room earlier, along with most of my devices). Never had any drops in quality before with that placement, but Orbi did not approve!
