mtlam
Nov 29, 2017Guide
Orbi DNS Disconnecting
Hi everyone, I'm already in contact with support about this issue but wanted to see if you guys could give me some input on my current issue. So this issue occurs on the satellite units wheth...
Heiruspecs
Nov 29, 2017Guide
On your main router that is handling the routing/DHCP, reserve IP addresses for your satellites.
Turn off your routers wifi (with Orbi router in AP-mode).
Make sure MU-MIMO and beaming is turned off.
Also, is your router well-placed? What lastly did the trick for me and my Orbi troubles was placing the router in the center of the house, away from any concrete walls (had it in my living room earlier, along with most of my devices). Never had any drops in quality before with that placement, but Orbi did not approve!
mtlam
Nov 29, 2017Guide
I think assigning a static ip to the satellite unit might've done the trick. I'll have to keep stressing the network and see if it still disconnects or not.
My router's wifi is off and MU-MIMO and beaming is off.
Router is placed in my living room with the two satellites on the second floor.
- HeiruspecsNov 29, 2017GuideI’m glad it works!
Keep me updated if they start acting up again!- mtlamNov 30, 2017Guide
It did make it a lot more stable though I still get disconnects after stressing it from time to time. I wonder if theres still some ip conflict still going on.
