Lenster45
Aug 16, 2019Aspirant
orbi dns settings
I am running windows 10. If I set up the Orbi to use specific DSN server addresses and leave the Windows 10 IVP4 properties to obtain DNS server automatically, when I runthe DNSbench program, it sho...
Fl1ntstone
Aug 16, 2019Apprentice
Hi,
As Orbi allocates your workstation an IP address via DHCP, the Orbi will also resolve DNS for you and gives you the IP address 192.168.1.1 of the Orbi to do that. I don't believe that the Orbi DHCP server can give you the specified DNS servers that you require? If it is an issue for you then manually set them up?
CheerZ
