Lenster45
Aug 16, 2019Aspirant
orbi dns settings
I am running windows 10. If I set up the Orbi to use specific DSN server addresses and leave the Windows 10 IVP4 properties to obtain DNS server automatically, when I runthe DNSbench program, it sho...
CrimpOn
Aug 16, 2019Guru - Experienced User
FURRYe38 wrote:How do I set up Orbi and Windows 10 so the ORBI decides which DNS servers to use.
By the way, I have rebooted windows after each change.
When the Windows PC is set to get DNS entries using DHCP, the Orbi always responds with its own IP address and acts as a DNS relay. Numerous people have asked for a way to get Orbi to hand out other DNS entries, and it simply cannot be made to do that.
There are only two ways to have devices use other DNS servers: (1) set up the device with static entries for DNS, and (2) use a different DHCP server. For one or two devices, option (1) is not too horrible. For many devices, it would be a "chore". Option (2) requires investment in more hardware and considerable technical skill.
Sorry.
Yes this is a given with NG routers and some other Mfr routers. Some mfrs allow users to disable the DNS proxy or relay on the router thus allowing the actual DNS addresses to pass thru to connected devices.
Please include the OP :smileywink: Lenster45
- Lenster45Aug 16, 2019Aspirant
OK here is what I have found. If I set up DNS server names in the ORBI and leave windows as automatic DNS then WIndows uses 192.168.1.1 which in turn takes it to my ISP which is horrible. But my non-windows devices wind up using the DNS servers specified in the Orbi and perform much better. When I set windows to specific DNS server names and leave the same server names in the Orbi, then everything uses the specified DNS servers and al perfom well.
- FURRYe38Aug 16, 2019Guru - Experienced User
You using custome DNS addresses or ISP DNS addresses? What happens if you let the RBR detect ISP dns?
The Modem is a Motorola SB 6121. Windows is ethernet cable connected to the ORBI
If I set both Windows and the Orbi to obtain DNS address automatically then all lookups go to my ISP as do all my non windows devices hooked up on wifi .
I then run DNSBenchmark and pick two open dns server addresses.
I fI change only the orbi to "Use these DNS Servers" and plug in the two open dsn server address, then all the non windows devices go to the designated servers and are noticably faster, but WIndows still uses 192.168.1.1 to go to my ISP. I need to go into windows network configuration and set IVP4 properties to "use the folling DNS server address and plug in the open DNS server addresses then I flush DNS cache, windows then uses the specified addresses and is noticibly faster.
My post was not that I couldn't get it working, but why windows would not let the ORBI use the open DNS addresses I plugged into the orbi if I left windows as optain server address automatically.
