Lenster45
Aug 16, 2019Aspirant
orbi dns settings
I am running windows 10. If I set up the Orbi to use specific DSN server addresses and leave the Windows 10 IVP4 properties to obtain DNS server automatically, when I runthe DNSbench program, it sho...
GeeksAdvice
Aug 24, 2019Aspirant
HI,
It may help you changing dns to 8.8.8.8 and 8.8.4.4
afterwardes flush dns https://geeksadvice.com/flush-dns/
hope it helps
Aug 24, 2019Guru - Experienced User
The user wants to keep using Open DNS servers with the Orbi system. The system is working as extected as the system will use any DNS that the user specifies however all connected clients will get a single router IP address for there DNS. The orbi acts as a DNS proxy or relay.
Thanks for posting.
