toblerpwn
Oct 27, 2017Aspirant
Orbi does not save/retain VLAN settings
Firmware V2.0.0.74 I'm trying to configure CenturyLink Fiber Internet (1gb) on my Netgear Orbi. And failing! As the subject says, whenever I try to change or save any attribute of the default...
- Jan 04, 2018
MikeW12 - Indeed, this was fixed by a firmware update. See: https://community.netgear.com/t5/Orbi/BUG-Cannot-edit-quot-Internet-quot-VLAN-settings-e-g-Priority/m-p/1409025
DarrenM
Oct 31, 2017Sr. NETGEAR Moderator
Have you tried from another device?
DarrenM
toblerpwn
Oct 31, 2017Aspirant
Hi Darren!
I just tried from my iPad using Chrome, which failed, and then again on an old Dell Windows 10 laptop on both Chrome and Edge, which also failed. My main device is a MacBook Pro, which failed using both Safair and Chrome.
Also note that I couldn't figure out how to edit this post originally, so I made a new post the following day with more detailed steps - that may help better illustrate what I'm seeing:
If that new post is more clear, or more helpful for the community, please feel free to resume the conversation there. Else this works fine, too!
Ultimately, I am trying to set up CenturyLink Fiber Internet. This requires PPPoE authentication (which is working) and support for a tagged VLAN ID of 201 coming into the "WAN" port (which is NOT working).
Right now I have successfully set up PPPoE authentication at the Orbi level, but between the Fiber line (ONT) and the Orbi, I've had to use a managed switch that handles the "de-tagging" of VLAN ID 201. For obvious reasons I'd like to remove this switch (it's otherwise a pointless failure point & expense) and handle everything with the Orbi. I believe the only thing preventing me from doing this is this the inability to manage the VLAN settings on the core "Internet" port, as described above. Unless I'm doing something wrong?
- DarrenMNov 17, 2017Sr. NETGEAR Moderator
Hello toblerpwn
We are looking into why the VLAN settings are not saving will let you know when I have update.
DarrenM
