AC360
Jan 03, 2020Aspirant
Orbi Doesn't Port Forward 80 to Synology
I am trying to setup synology external access with my ORBI. I was able to quickly setup port forwards using UPnP and all the port seems to be connecting... except port 80. And I think i'm unable to...
AC360
Jan 07, 2020Aspirant
I was advised by Synology service tech to not use UPnP as it is unstable and instead to setup port forwarding rules manually.... followed the steps in this article:
https://kb.netgear.com/31069/How-do-I-configure-port-forwarding-on-my-Orbi-system
I added 3 custom service rules. 1)l ports 5000-5001 2) ports 80, 443 3) ports 9025-9040, 5002, 5004.
I also rebooted the Orbi after adding these changes.
When I check with a port checker tool, all of them are closed...
What can I be missing?
CrimpOn
Jan 07, 2020Guru - Experienced User
Can you take a screen shot of the port forwarding page?
(I do not think "rebooting" is necessary.)
- AC360Jan 08, 2020Aspirant
Here is the screen shot of the Port Forwarding page....
- CrimpOnJan 08, 2020Guru - Experienced User
This certaily looks correct to me. In all this, I forgot to ask what the Orbi is connected to. Obviously, the Orbi is in "router" mode. If it is connected to another router rather than directly to the internet modem, port forwarding is not going to work. One quick test is to do a "trace route" to some external IP adddress, such as Google DNS (8.8.8.8) from any machine on your LAN.
The first "hop" should be 192.168.1.1 (the Orbi gateway).
The second "hop" should be a public IP address, i.e. not one that starts with 192.168 or 10.0
- AC360Jan 10, 2020Aspirant
It is in router mode... and i have the ORBI connected directly to the modem.
Now, when I did the tracer test, the first "hop" was to 192.168.1.1. However, the second "hop" was not to Google's 8.8.8.8.
The second "hop" says ***
3 - 9 are to various addresses
and the 10th is 8.8.8.8
