LarryNewYork
Apr 11, 2018Aspirant
Orbi does't let me see RoonReady speaker wirelessly
I installed Orbi a few days ago and it has helped give me excellent WiFi throughout my apartment. However, I'm having trouble getting my wireless speaker, an ELAC Discovery Z3, to be seen by my ...
Apr 11, 2018Guru - Experienced User
Try setting security to OPEN on the router temporarily. Will the devices connect then? If so, re-enable WPA and TPIK security and test again.
What version of FW are you using?
I would turn OFF the satellite and test with the orbi router first and see if all your devices connect to it. Test with it alone.
Might try disabling MIMO, Daisy chain, Fast Roaming, and Ipv6 on the router as well.
LarryNewYork
Apr 12, 2018Aspirant
FURRYe38 wrote:Try setting security to OPEN on the router temporarily. Will the devices connect then? If so, re-enable WPA and TPIK security and test again.
Thanks for that suggestion. I have been waiting for somebody from NetGear support to get back to me to try to debug the problem
I will try what you say.
