cmshinkle
Sep 12, 2018Aspirant
Orbi DoS Attack
Hello,
I'm having issues with my network. It can get really slow and, at times, I'm unable to even connect. I'll reboot the router just so that I an login to the admin portal. When I check the ...
Sep 13, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
cmshinkle
Sep 13, 2018Aspirant
Thanks for the reply. Are those listed in order of preference? Can you help me understand the pros and cons between the three options?
