cmshinkle
Sep 12, 2018Aspirant
Orbi DoS Attack
Hello,
I'm having issues with my network. It can get really slow and, at times, I'm unable to even connect. I'll reboot the router just so that I an login to the admin portal. When I check the ...
Sep 13, 2018Guru - Experienced User
Yes, there in order of preference.
Since your modem already has a router, the Orbi has a router too. Orbi would be the preferred router to use.
If the modem can't be bridged, then the use of the DMZ can help so you can use the Orbi in router mode.
If the modem needs to be used as a router, then the Orbi can be used in AP mode with out it's router being used.
