WattsOrbi
Aug 28, 2021Aspirant
Orbi down: RBR20 is not connecting. Confirmed with Spectrum that WiFi and Router (3 months old) are
There was a brief powers failure here this afternoon. RBR20 now has magenta light, rebooting has had no effect. Spectrum is sure things in there end are good, no other Internet issues in my area. Thou...
- Aug 29, 2021
WattsOrbi wrote:
There was a brief powers failure here this afternoon. RBR20 now has magenta light, rebooting has had no effect. Spectrum is sure things in there end are good, no other Internet issues in my area. Thoughts?Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
WattsOrbi
That’s a new modem from Spectrum ;=}
- michaelkenwardAug 29, 2021Guru - Experienced User
WattsOrbi wrote:
That’s a new modem from Spectrum ;=}Does it have a make and model numvber? (Spectrum doesn't make modems.)
- WattsOrbiAug 29, 2021AspirantSolved, thanks!
WattsOrbi wrote:
Solved, thanks!Excellent. It is often the simple ones that bite us.
There can't be many of us who haven't got that one wrong.
Fortunately, it is easy to remember!
