Wyrax
May 09, 2019Follower
Orbi download irregularities
Hey all! Im currently having an issue with downloads. Steam, Spotify, and various app/web stores can't download anything. Steam in particular is being enigmatic, as every couple minutes it allows me t...
May 09, 2019Guru - Experienced User
What modem and firmware are you using?
Does it work fine if you're hardwired into the modem? Just want to make sure its an orbi issue specifically.
Are you using a custom dns? Or have you tried changing the dns server?
