Wyrax
May 09, 2019Follower
Orbi download irregularities
Hey all! Im currently having an issue with downloads. Steam, Spotify, and various app/web stores can't download anything. Steam in particular is being enigmatic, as every couple minutes it allows me t...
ekhalil
May 09, 2019Master
Wyrax wrote:
Hey all! Im currently having an issue with downloads. Steam, Spotify, and various app/web stores can't download anything. Steam in particular is being enigmatic, as every couple minutes it allows me to download 50kb then completely stops the download. The weird part is, I can load web pages and web videos (YouTube, news articles). The download doesn't work on both my phone using wifi or my computer hooked from an ethernet chord into a satellite.
One of the reasons that can cause this issue is having double NAT in your network. If your ISP modem is acting as a router and does NATing on the incoming WAN traffic then this can cause different issues since Orbi is also doing NATing. You need to check if you have double NAT.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server)
- If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
- If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
