chuahyenhua
Jun 14, 2017Apprentice
Orbi drop ping
Today, i was wondering why is my internet moving so slow. My mac is connected to the router via ethernet. when i tried to ping to the Orbi router, this is the result ========= Ping result =======...
netwrks
Jun 14, 2017Master
You have an bunch of this on your logs:
[LAN access from remote] from 61.164.149.211:56664 to 192.168.68.252:81, Wednesday, June 14, 2017 08:12:24
[LAN access from remote] from 61.164.149.211:55191 to 192.168.68.252:81, Wednesday, June 14, 2017 08:12:24
[LAN access from remote] from 61.164.149.211:53776 to 192.168.68.252:81, Wednesday, June 14, 2017 08:12:23
[LAN access from remote] from 61.164.149.211:52344 to 192.168.68.252:81, Wednesday, June 14, 2017 08:12:23
IPLOOKUP shows 61.164.149 is from China..
Which means, someone other than you, is accessing your router..
Do you have remote access or UPNP, or DMZ enabled on the Orbi?
chuahyenhua
Port 81 is the apache web server used in the pc.
Is there a way to log whats happening when someone comes into this port?
please advise
thanks
chris
