chuahyenhua
Jun 14, 2017Apprentice
Orbi drop ping
Today, i was wondering why is my internet moving so slow. My mac is connected to the router via ethernet. when i tried to ping to the Orbi router, this is the result ========= Ping result =======...
netwrks
Jun 15, 2017Master
Port forwarding comes to mind, if the Orbi supports it. Then you could shut down UPnP..
chuahyenhua
Jun 27, 2017Apprentice
Hi
anyone can see why traceroute can have no timing at all or just show *
attached is the log where i use my mac to perform a traceroute to the Orbi router via a RJ45 cable
======== traceroute result ===========
iMac:~ chrischuah$ traceroute 192.168.68.1
traceroute to 192.168.68.1 (192.168.68.1), 64 hops max, 52 byte packets
1 * 192.168.68.1 (192.168.68.1) 0.502 ms 0.366 ms
1 192.168.68.1 (192.168.68.1) 1.057 ms 0.814 ms 0.734 ms
1 192.168.68.1 (192.168.68.1) 0.602 ms * *
1 192.168.68.1 (192.168.68.1) 1.075 ms * *
1 192.168.68.1 (192.168.68.1) 0.991 ms 0.741 ms *
1 192.168.68.1 (192.168.68.1) 0.934 ms 0.931 ms 0.679 ms
1 192.168.68.1 (192.168.68.1) 1.006 ms * 0.771 ms
1 192.168.68.1 (192.168.68.1) 0.633 ms 0.388 ms *
1 * 192.168.68.1 (192.168.68.1) 0.748 ms 0.591 ms
1 192.168.68.1 (192.168.68.1) 0.952 ms 0.729 ms *
1 192.168.68.1 (192.168.68.1) 1.019 ms 3.251 ms 0.654 ms
1 192.168.68.1 (192.168.68.1) 0.935 ms * 0.760 ms
