Deez72
Feb 06, 2018Tutor
Orbi Dropped connections
Orbi system is pure garbage and a waste of 400 dollars. Constant lose of internet, terrible WiFi speeds, dropped connections , the list goes on. I have even called support and the only option was to ...
Retired_Member
Feb 07, 2018mine has been working ok since November. several auto firmware updates ( i don't do beta). simple router to sats setup and dozens of devices.
martyfp
Feb 07, 2018Luminary
mine works brilliantly. hope you find something that works for you.
- webminsterFeb 07, 2018Luminary
Reverting firmware can help. Keeping it there is a big problem. After following the unofficial process to try to disable auto-updates, I keep getting upgraded anyway.
- PyroDogFeb 07, 2018Apprentice
wrote:Reverting firmware can help. Keeping it there is a big problem. After following the unofficial process to try to disable auto-updates, I keep getting upgraded anyway.
I was on the same boat as you. I had to block all the internet access from the Orbi units without affecting the devices conected through them using my firewall.
