Deez72
Feb 07, 2018Tutor
Orbi Dropped connections
Orbi system is pure garbage and a waste of 400 dollars. Constant lose of internet, terrible WiFi speeds, dropped connections , the list goes on. I have even called support and the only option was to ...
webminster
Feb 07, 2018Luminary
Reverting firmware can help. Keeping it there is a big problem. After following the unofficial process to try to disable auto-updates, I keep getting upgraded anyway.
PyroDog
Feb 08, 2018Apprentice
wrote:Reverting firmware can help. Keeping it there is a big problem. After following the unofficial process to try to disable auto-updates, I keep getting upgraded anyway.
I was on the same boat as you. I had to block all the internet access from the Orbi units without affecting the devices conected through them using my firewall.
