astrojohn
Jun 06, 2018Tutor
Orbi dropping connection to iPads
Orbi has been in use since May 18, 2018 and started briefly dropping iPad connections. The first one to drop was yesterday (Jun 5, 2018) on the main router and it was 10 feet or so away. The second...
Jun 07, 2018Guru - Experienced User
Change to 1 6 or 11 on 2.4Ghz. Least used of these channelr.
if you have many other wifi nieghbors, you maybe in a wifi congested area FYI which will be hard to deal with. You may need to turn down the power of your system to create a smaller foot print which will have less impact and interference from others. Which maybe a reason why your seeing these problems I presume.
MIMO is only needed if you have lots of MIMO supporting devices. It's not required to have it on either. Just a trouble shooting step as well.
