Markesyd
Jul 08, 2018Guide
Orbi dropping connection to modem
I have searched the forums and am still having the issue so I wanted to see if anyone here has some suggestions...
SETUP:
I have had my Netgear ADSL2+ modem (DM111Pv2) running with an Apple T...
- Jul 22, 2018
FYI, the modem(s) taht I am using is modem function only, no wifi or router. Purely modem.
So I finally relented and purchased a new Netgear modem, that had firmware updates as recently as this year.
So far Orbi has been up for several days with no dropping communication to the modem.
So it appears the only solution that worked was to replace my 3-year old modem that was working perfectly with my Apple Time Capsule wifi router. Dissapointed that upgrading to Orbi necessiated replacing my modem as well... :-(
Jul 09, 2018Guru - Experienced User
Is the modem handling the PPPoE service or is the modem bridged and the Orbi handling PPPoE services?
What mode is the router running in? Router or AP mode?
Ensure it's a good quallty LAN cable between the modem and router.
Also be aware that the ISP Modem only supports 100Mb LAN connections, the Orbi supports 1000Mb connections.
You have a older modem so it maybe possibly time to upgrade the modem...
Markesyd
Jul 09, 2018Guide
Thanks for your reply.
Answering your questions:
- modem is handling PPPoE (again, modem status lights are all green indicating modem shows internet connection OK. It has an internet connection status light that will show red if the modem can't reach the internet).
- Orbi is in router mode, as I have a printer, NAS and iMac connected to it via ethernet
- I am using the LAN cable privided with the Orbi. If this cable is not sufficient quality, then Netgear should not be providing it in the Orbi package!
Are you suggesting that the LAN communication is too slow for the Orbi, so it looses connection to the modem? Although the modem supports 100Mbps and Orbi supports 1000Mbps I am stuck on ADSL that only reaches 16Mbps on a good day. The bottleneck is upstream of the modem, not within my network.
Netgear still lists this exact modem as a current model for sale (they only offer 2 modems here in Australia), so I don't agree that the modem is out of date and should be upgraded with a new one. And the fact that they are both Netgear products should increase compatability, not decrease it.
Unless you have any other suggestions, I'm thinking to add in a simple 5-port switch between the Orbi and the modem to handle the router functions, and put Orbi in AP mode just to handle the Wifi traffic. Maybe Orbi will be happier talking to a switch instead of the modem... ?? See attached diagram.
- FURRYe38Jul 10, 2018Guru - Experienced User
If the modem is doing the PPPoE then try lowering the MTU value on the Orbi from 1500 to 1472 or 1496 and see. DSL uses different MTU values. You can ask your ISP about what MTU values they support.
You might ask the ISP to bridge the modem and let the Orbi do the PPPoE handling as well.
Or let the modem do the PPPoE and use the Orbi in AP mode.
Router Mfr will never use great quality cables in box. I always use my own bought from other places. At most the in box cable is good for getting things running out of the box.
Maybe however the older HW gets and newer designs in HW, doesn't always mean it will always work or be more compatible. As older HW gets older, theres less upgrades in FW and less problems fixed as time goes forward. Yes it should work however just be aware, older HW may pose problems.
The bottle will be the modem since it's only supporting of 100Mb and yes the Orbi should handle that fine. Possible issue could be a break down in connection with the modem. I would try either bridging the modem and let the Orbi handle PPPoE and set the correct MTU value that your ISP requires and see how it does. Or run the Orbi in AP mode with the modem handling PPPoE and see what happens.
- MarkesydJul 14, 2018Guide
Update:
1) When I put the Orbi behind the TimeCapsule, and put it in AP mode, I had 3 days uptime with no dropped communication from the Orbi. So the issue is definitely bewteen the Orbi and the Netgear modem.
2) Changed back to original configuration (Orbi on router mode connected directly to modem), and changed the MTU to proper value (1492 for my ISP). Unfortuantely my modem doesn't have an open to let downstream device handle PPPoE, so the modem is still doing that task.
On Saturday night 14th at approx 17:44, I was watching Netflix via VPN to USA, and it suddenly hung again. Attached is the log from the Orbi when it hung.
I disabled DoS scan and UPnP, and rebooted eveything.
Anyone have a clue about the DoS Attack entries or the UPnP rule??? (FYI the 192.168.1.5 is my iMac that is attached to Orbi via ethernet cable). At that time the iMac was idle and I have no idea what triggered the UPnP events on the iMac...
- FURRYe38Jul 15, 2018Guru - Experienced User
Does the modem have a DMZ?
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
Also might be time to ask the ISP for a different modem possibly that can be bridged if possible.
