Markesyd's avatar
Jul 08, 2018
Orbi dropping connection to modem
I have searched the forums and am still having the issue so I wanted to see if anyone here has some suggestions...   SETUP: I have had my Netgear ADSL2+ modem (DM111Pv2) running with an Apple T...
  • Markesyd's avatar
    Markesyd
    Jul 22, 2018
    FYI, the modem(s) taht I am using is modem function only, no wifi or router. Purely modem.
    So I finally relented and purchased a new Netgear modem, that had firmware updates as recently as this year.
    So far Orbi has been up for several days with no dropping communication to the modem.
    So it appears the only solution that worked was to replace my 3-year old modem that was working perfectly with my Apple Time Capsule wifi router. Dissapointed that upgrading to Orbi necessiated replacing my modem as well... :-(
