Appleuser2000
Apr 03, 2020Guide
Orbi dropping connections
I got new Orbi+1 Satellite and updated to latest to firmware after reading rave reviews. Unfortunately just couple of days in the Orbi Wifi signal disappears and I lose connection, the solution is to...
Apr 03, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Factory reset and setup from scratch. https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
Appleuser2000 wrote:I got new Orbi+1 Satellite and updated to latest to firmware after reading rave reviews. Unfortunately just couple of days in the Orbi Wifi signal disappears and I lose connection, the solution is to shutdown the device and restart. A less than pleasant expereince for a $400 brand new device.
For now I have shutdown MU-MIMO, Beamforming, Fast Roaming, and Daisy Chain Topolgy and drop 5GHz power to 75%. I read about Orbi dropout but that was supposedly fixed in firmware updates a couple of years ago. Whats the point of paying for these features if we are going to have not to use them to keep a stable connection?
My second issue is that the satellite will lose its connection with the main unit on reboot and have to re-sync each time the power is shut off.
Retired_Member
Apr 03, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
:smileysad:
