Appleuser2000
Apr 03, 2020Guide
Orbi dropping connections
I got new Orbi+1 Satellite and updated to latest to firmware after reading rave reviews. Unfortunately just couple of days in the Orbi Wifi signal disappears and I lose connection, the solution is to...
Retired_Member
Apr 03, 2020firmware?
Appleuser2000
Apr 03, 2020Guide
Retired_Member wrote:firmware?
the latest as I have mentioned 2.5.1.8
- Retired_MemberApr 03, 2020
The are numerous problems with that one
go to download and look for a earlier version
- Appleuser2000Apr 03, 2020Guidewhich earlier version is best?
Also, Netgear forces auto updates so if I use earlier one it will just auto update to this one- Retired_MemberApr 03, 2020
i've been on v2.3.5.30 since October 2019 and for the most part all is well
ng only pushes firmware that is critical
