Appleuser2000
Apr 03, 2020Guide
Orbi dropping connections
I got new Orbi+1 Satellite and updated to latest to firmware after reading rave reviews. Unfortunately just couple of days in the Orbi Wifi signal disappears and I lose connection, the solution is to...
Appleuser2000
Apr 03, 2020Guide
Retired_Member wrote:firmware?
the latest as I have mentioned 2.5.1.8
Retired_Member
Apr 03, 2020
The are numerous problems with that one
go to download and look for a earlier version
- Appleuser2000Apr 03, 2020Guidewhich earlier version is best?
Also, Netgear forces auto updates so if I use earlier one it will just auto update to this one- Retired_MemberApr 03, 2020
i've been on v2.3.5.30 since October 2019 and for the most part all is well
ng only pushes firmware that is critical
- FURRYe38Apr 04, 2020Guru - Experienced User
You can try Voxels FW for Orbi:
You can revert back to stock FW if it doesn't work out for you.
ALso be sure to try a factory reset and setup from scratch on your current v2.5.1.8 version. I and others have working systems on v2.5.1.8. Good last resort step to try.
https://www.youtube.com/watch?v=cMw4ePACgc4
https://www.howtogeek.com/434350/how-to-factory-reset-a-router/Good Luck.
