Appleuser2000
Apr 03, 2020Guide
Orbi dropping connections
I got new Orbi+1 Satellite and updated to latest to firmware after reading rave reviews. Unfortunately just couple of days in the Orbi Wifi signal disappears and I lose connection, the solution is to...
BigRune
Apr 04, 2020Apprentice
Appleuser2000 If the Orbi is brand new I recommend you to return it if possible. The are a lot lf problems with previous fw versions also. I had similar problems on fwV2.3.5.30 that could not be configured away. There are countless similar topics in the community topic history and no clear solutions.
Bad software design, substandard routines for testing and release of new softwares makes Orbi totally unreliable and now, in the end of its product life cycle, it will probably never reach a stable state.
Spare your time, money and efforts and spend it on something that pays back instead :thumbsup:.
Appleuser2000
Apr 04, 2020Guide
What other maker do you suggest for mesh system? Netgear Orbi is contantly getting praised and the product is a flagship, they released a new Wifi 6 Orbis. Its been out for sometime but there has been no real advances in technology really to make it old.
There is Ubiquiti but you have to wire the access points.
- BigRuneApr 04, 2020Apprentice
Appleuser2000 wrote:What other maker do you suggest for mesh system? Netgear Orbi is contantly getting praised and the product is a flagship, they released a new Wifi 6 Orbis. Its been out for sometime but there has been no real advances in technology really to make it old.
Do your own research, with your own requirements đ. Look into forums and communities. Do not pay too much attention to all sponsored router reviews flooding internet.
Lack of research made me buy Netgear Orbi (ouch! :smileylol:). My following research online and IRL led me to a Ubiquiti Unifi solution. Unifi is a kind of SOHO/PROsumer networking with a lot of flexibility. I liked the new "Dream Machine" that made the entry to Unifi simple and decided to give it a try.
The Ubiquiri Unifi Dream Machine combines all standalone Unifi network parts needed. Actually delivering better performance to a lower price than buing separate Unifi parts, (Gateway, Cloud key, switch, access point).
UDM has a built in AP ("wired") that can connect additional Unifi AP wireless. I have not studied wireless downlinks as I have a Wired NanoHD access point on 2nd floor (works great đ ). Read more here : https://help.ubnt.com/hc/en-us/articles/115002262328-UniFi-Configuring-Wireless-Uplink
