shanwa
Oct 24, 2017Tutor
Orbi dropping internet connection finally resolved!
Hi Everyone, So I've had countless issues with my Orbi RBK50 where I've been frustrated, called support, sent a number of support messages, with no response. Support even initially asked me to ta...
snajmus
Oct 24, 2017Aspirant
Hello Shanwa,
Thanks for your detailed experience in resolving a major issue through trial and error. Would you mind, writing a step by step process for someone new who is trying this, so that he/she doesn't have to go through the same trouble you went through. Key things I got from your note are this:
1. Ask the ISP to provide a secondary address
2. Turn off the Wifi on the incoming modem
3. Connect the Orbi main unit to the modem and set it up as a router. (I am not clear on the MAC address set up etc. - can you elaborate)
4. Connect the two satellite units (in which mode).
I am sure there are more details than above. Do you mind taking the time to elaborate on this based on your experience.
- shanwaOct 24, 2017Tutor
Yep for sure!
Either ask your ISP for a secondary address so you can then allow IP passthrough on your modem or bridge your modem/router depending on the configurations it has. Disregard the mac address setup, as this is dependent on your modem/router and its capabilities along with what your ISP can do for you. Here's a good community thread from my ISP on bridging/IP passthrough.
My satellites just connect to the RBR50 without issue. There's no need to set any configurations on these as they should just obtain settings from the RBR50.
