Abeheary
Feb 08, 2018Aspirant
Orbi dropping internet connection when ethernets connected
Suddenly my orbi dropped connection, I had to reset it as nothing works. Upon reset it’s working but each time I connect any Ethernet cable to it, it disconnects. Please help. It was fine for the past...
DarrenM
Mar 07, 2018Sr. NETGEAR Moderator
You may want to contact support at this point could be a hardware issue they will be able to troubleshoot with you.
http://www.netgear.com/support/contact.aspx
DarrenM
