Abeheary
Feb 08, 2018Aspirant
Orbi dropping internet connection when ethernets connected
Suddenly my orbi dropped connection, I had to reset it as nothing works. Upon reset it’s working but each time I connect any Ethernet cable to it, it disconnects. Please help. It was fine for the past...
Abeheary
Mar 04, 2018Aspirant
Yes all on the the new firmware. Ethernet not functioning on the main device. Once I connect them it disconnects an turns magneta. And now even wireless keeps on disconnecting. I restarted my orbi and the je main router but still.
RocketSquirrel
Mar 07, 2018Luminary
I think the Orbi hardware is pretty solid. And I wince a little when someone says “I’m on the latest firmware” without specifying the version number. Both 2.0 and 2.1 may be considered the latest version because 2.1 was withdrawn. And 2.2 is on the horizon.
2.0 - wired backhaul kills your whole network; wireless backhaul works
2.1 - wired backhaul works; reportedly suffers from connection drops
2.2 - works well but isn’t finished, still in pre-release, can be obtained by asking Support
I’m running 2.2.0 and it’s unfinished but rock solid.
