Kael2618
Sep 04, 2017Aspirant
Orbi dropping internet connection
My Internet keeps dropping especially the upload speed I rebooted the Orbi system twice and I also reset the router in the satellite and I'm still having the same issue I got the System On April 23, 2...
forest63
Jan 13, 2018Aspirant
Thanks for the help. I am pretty sure that my ISP cannot do anything more than disconnect the wi-fi function on their modem/router combination which was done as I have talked twice to them regarding my connectivity issue. They said everything was running as should be on their end on the internet 150 mbps plan. The router/modem from shaw is in link below at bottom of page. Any additional help would sure be grateful.
https://www.shaw.ca/advanced-wifi-modem/
Jgvd
Obtain your gateway brand and model number. Goggle how to disconnect the WiFi. Follow the instructions. It worked for me. Also on the Orbi log page at the very top it will show time zone if not yours correct to yours. Seems silly but again it made a difference for me.
- forest63Jan 13, 2018Aspirant
Thanks. Wifi is disconnected. And I did change the time zone from Eastern Canada to Mt. Pacfic. I changed the time zone yesterday afternoon and the wi-fi is disconnected. It is now a wait and see if changing the time zone will solve my problem. Again Thanks!!
- sleepr88Jan 13, 2018Apprentice
it's not a problem with ISP equipment (nothing has changed with it in the past year)... and updating the time zone didn't help either
- forest63Jan 14, 2018Aspirant
I have to agree. My wife and I went out last night and when we got home, she had to manually prompt her Samsung Galaxy S7 edge to connect to the Orbi wi-fi. It is obviously a firmware issue that has not been resolved as of yet. I have wasted alot of time with this issue and now we have to always double check that the phones are connecting to the wi-fi. Not good!!! The problems seem to be compounding. Our decison is becoming very obvious as we in all likely hood will be returning it and will get the Linksys Velop.
- sleepr88Jan 15, 2018Apprentice
Google Home App v1.26.30.8 on Android devices seems to be the cause
- AZCraigMar 08, 2018Aspirant
Based on the comments about Android conflicts, I looked through my list of attached devices and found one Android that, interestingly, had the same IP address as two other devices. I used the Orbi app to block the Android device (likely a Samsung TV that really doesn't need internet access except for firmware updates) and my Orbi lockup problem seems to be history. It's been about a week with no problems.
