Mrdudley
Jan 10, 2018Aspirant
Orbi dropping internet connection
Help please! I have just installed a Netgear DM200 successfully and set up as modem only mode. I have then attached and successfully installed an Orbi rm40 plus one satellite. Latest firmware has bee...
DarrenM
Jan 15, 2018Sr. NETGEAR Moderator
What firmware are you on? also is it just the satellite disconnecting or are you getting wifi drops across both units?
DarrenM
Mrdudley
Jan 16, 2018Aspirant
Hi Darren
Thanks for getting back to me. It’s dropping off on both units and can be for just a short period (minutes) and as was the case last night for hours!
Yesterday I updated the firmware again and I am now on 2.1.1.16 for both the router and the satellite.
Hope you can help!
Tks again
Tim
Hope you can help!
Tks again
Tim
- DarrenMJan 18, 2018Sr. NETGEAR Moderator
Do you have any google homes or chromecasts on the network? There is a know issue with google devices crashing routers and causing other issues.
DarrenM
