mpf541
Jan 24, 2018Apprentice
Orbi dropping internet connection
I have a RBK50 that i use with ATT fiber. From the ATT modem I have the orbi and A cisco router. I have 2 different networks. The cisco router works properly and I never have any issue losing the int...
DarrenM
Jan 30, 2018Sr. NETGEAR Moderator
I would try to enable beamforming and mumimo on the unit see if that helps also try to adjust the wireless channels. Make sure you have the latest firmware on Orbi.
DarrenM
mpf541
Feb 08, 2018Apprentice
Not sure how any of this would help. It is the orbi dropping the internet connection.
