mrnome201
Aug 03, 2020Aspirant
Orbi dropping internet
Hello - I have a RBR50 Orbi router and 1 satellite. I am based in New Jersey. I used to have Verizon TV and internet where the signal was coaxial. I setup Orbi in AP mode to work w/ Verizon router...
mrnome201
Aug 12, 2020Aspirant
Hi - I reset my Orbi setup and it fixed the issue. thank you very much.
Mstrbig
Aug 12, 2020Master
That was going to be my suggestion. When changing a router or remoming it and goint direct to the ONT, it is important to reboot or reset the Orbi router, if reset does not fix the problem. It's the same thing on a new install if dealing with a used Orbi router. Resetting it and rebooting the ISP modem/router eliminates those types of problems you experienced.
Glad you got it working. I know how frustrating it can be.
