SCMrEason
Apr 08, 2021Guide
Orbi Dropping Internet
Somebody out there probably needs this solution. Maybe this post will be easier than my original post for someone else to find. Much thanks to CrimpOn for posting it to my question ten days ago. Unti...
- Apr 08, 2021
You can ask the forum moderator for a beta if you like thats being offered.
SCMrEason wrote:Somebody out there probably needs this solution. Maybe this post will be easier than my original post for someone else to find. Much thanks to CrimpOn for posting it to my question ten days ago. Until this problem began, my Orbi had worked without interuption for five months (excluding weather related). When the problem began, I was rebooting Orbi router 8-10 times per day in order to reconnect the internet.
"There is a horrible situation that started with the change in Daylight Saving Time that causes certain Orbi RBR50 routers to stop resolving Domain Names until they are restarted. Netgear engineers have traced the problem to a coding error in the Traffic Meter feature. Looks like there is abolutely no chance Netgear will release a firmware fix before April, so the easiest solution is to go into the Orbi web interface, Advanced Tab, Advanced Setup, Traffic Meter (toward the bottom of the menu) and uncheck "Enable Traffic Meter" and Apply." - CrimpOn
vajim
Apr 08, 2021Master
FURRYe38 wrote:You can ask the forum moderator for a beta if you like thats being offered.
did this problem also effect the wifi6 folks?
Apr 08, 2021Guru - Experienced User
No.
- tak1313Apr 08, 2021Luminary
From the AX forum
https://community.netgear.com/t5/Orbi-AX/Intermittent-DNS-Errors-and-WiFi-Issues/td-p/1950768
- FURRYe38Apr 08, 2021Guru - Experienced User
Orbi AC is effected by Traffic Meter. Something that doesn't effect Orbi AC. And NG has already acknowledged this probem is with in Traffic Meter. And confirmed by users here in the Orbi AC forum that when TM is disabled, solved the problem for them.
NG also has a beta avialble for the 50 series Orbi system for those who want to try it that is supposed to fix the TM issue.
tak1313 wrote:From the AX forum
