Baskura
Nov 03, 2017Follower
Orbi dropping wifi connections (iPhone)
Firstly I know there are many posts about these similar kind of issues already but I fail to see how Netgear, after all these years are still producing products with terrible firmware (or hardware - ...
Keatech
Jan 06, 2018Initiate
I have the same issue. Previous wifi access point had no issues. Intermittent disconnections especially on the satellite. Very poor product.
tclutes
Jan 09, 2018Guide
Same here it’s gotten to the point where I am considering digging out our old router, this system was too expensive to have so many connection issues. We can’t use WiFi Calling on our iPhones anymore calls will fail.
- brianbsiJan 09, 2018InitiateYes wifi calling gaming both don't work. I am not using the router functions either. Just wifi.
- joeyhangMar 29, 2018Aspirant
As suggested by Netgear vendor -
Please help to clarify that problem does the symptom only appear on iPhone? Does the symptom only affect one iphone client or all iphone device? And here is my suggestion for improve the WIFI strength.
(1) Go to http://routerlogin.net
(2) Go to Advanced> Advanced Setup > Wireless Setting
(3) Region change to "United States"
(4) Unclick the box of "Enable 20/40 Mhz Coexistence" (5)Click Apply Hope this help
