Baskura
Nov 03, 2017Follower
Orbi dropping wifi connections (iPhone)
Firstly I know there are many posts about these similar kind of issues already but I fail to see how Netgear, after all these years are still producing products with terrible firmware (or hardware - ...
brianbsi
Jan 09, 2018Initiate
Yes wifi calling gaming both don't work. I am not using the router functions either. Just wifi.
joeyhang
Mar 29, 2018Aspirant
As suggested by Netgear vendor -
Please help to clarify that problem does the symptom only appear on iPhone? Does the symptom only affect one iphone client or all iphone device? And here is my suggestion for improve the WIFI strength.
(1) Go to http://routerlogin.net
(2) Go to Advanced> Advanced Setup > Wireless Setting
(3) Region change to "United States"
(4) Unclick the box of "Enable 20/40 Mhz Coexistence" (5)Click Apply Hope this help
