Retired_Member
Oct 06, 2017Orbi dropping wireless connections
Hi, I'm having problems with wireless clients being disconnected. It works for awhile and then the client is disconnected, and then it reconnects and disconnects and this goes on for awhile and ...
DarrenM
Oct 09, 2017Sr. NETGEAR Moderator
Hello kiwiglen
Do you have beamforming and mumimo enabled in the advanced wireless settings?
DarrenM
