Retired_Member
Oct 06, 2017Orbi dropping wireless connections
Hi, I'm having problems with wireless clients being disconnected. It works for awhile and then the client is disconnected, and then it reconnects and disconnects and this goes on for awhile and ...
Retired_Member
Oct 14, 2017So the Satellite has been going for a few hours now and I'm back to getting dropped devices. It looks like it always devices attached to the satellite that drop off.
Is the Satellite faulty?
Glen
DarrenM
Oct 16, 2017Sr. NETGEAR Moderator
Hello Kiwiglen
Send me a PM with your name, email, and phone number and I will get support to work with you on these issues.
DarrenM
- TaskmastrOct 18, 2017Aspirant
I seem to be having the same or very similar trouble. I have the RBK53 from Costco, firmware updated to 2.0.0.74 on the router and two satellites. Different clients will lose internet connection or drop wifi and reconnect. The devices that lose internet connectivity (laptops, echo dots, FireTV Sticks) would get it back when I would hard reboot or turn off the satellite units. Several of our Echo dots will randomly lose connectivity and give you the 'I'm having trouble understanding right now." or out of the blue you hear the dot tell you it's lost the network connection. I disabled the daisy chain option, have tried enabled the beamforming and MU-MIMO with no noticable effect. Finally Sunday night I turned off the two satellite units and haven't had a device stall since and it was a fairly frequent and frustrating situation beforehand. I hope this can get straightened out because otherwise I definitely feel I would need to return the kit.
- JohnSibertDec 01, 2017Aspirant
Installed Orbi RBK50 with 2 satellites in August 2017 (4 months ago). Generally it solved my wifi coverage problems and the speeds have also improved. Lately, however the system has been randomly dropping wifi connections to android devices (we have 3 in our home) several times per day. Pressing Sync on the router and both satellites restors the connection for a shile. Firmware version V2.0.0.74.
- Retired_MemberDec 01, 2017
JohnSibert wrote:Installed Orbi RBK50 with 2 satellites in August 2017 (4 months ago). Generally it solved my wifi coverage problems and the speeds have also improved. Lately, however the system has been randomly dropping wifi connections to android devices (we have 3 in our home) several times per day. Pressing Sync on the router and both satellites restors the connection for a shile. Firmware version V2.0.0.74.
Common issue. Been happening since 1.10.x, however Netgear says it's a Samsung problem (it's not, also affects Windows Surface Pro 2017's, Google Home's, Chromecasts and Echo devices at the same moments it affects the Samsung Android devices).
- lawlushJan 23, 2018Aspirant
Same issue here. Suddenly as of the last few days several of my devices won’t connect to Orbi while others are connecting. For example, IPad Pro is connecting and laptop is connecting but another iPad suddenly isn’t. I reset all devices including Orbi and the iPad will connect but now the laptop won’t. Have latest firmware. Really awful! Thanks.
