Anonymous
Oct 06, 2017Orbi dropping wireless connections
Hi, I'm having problems with wireless clients being disconnected. It works for awhile and then the client is disconnected, and then it reconnects and disconnects and this goes on for awhile and ...
Anonymous
Dec 01, 2017
JohnSibert wrote:Installed Orbi RBK50 with 2 satellites in August 2017 (4 months ago). Generally it solved my wifi coverage problems and the speeds have also improved. Lately, however the system has been randomly dropping wifi connections to android devices (we have 3 in our home) several times per day. Pressing Sync on the router and both satellites restors the connection for a shile. Firmware version V2.0.0.74.
Common issue. Been happening since 1.10.x, however Netgear says it's a Samsung problem (it's not, also affects Windows Surface Pro 2017's, Google Home's, Chromecasts and Echo devices at the same moments it affects the Samsung Android devices).
JohnSibert
Dec 02, 2017Aspirant
Thanks for the info. The wifi is working fine for HP printer, Panasonic TV, and chromecast. The random android drops occur on 2 LG phones and 1 HTC tablet.
