ydes
Sep 29, 2019Aspirant
Orbi drops interernet connection
Hello I have an rbk53 (firmware V2.3.5.30) connected to a Genexis Hybrid modem (FTTH). From my PCs/Devices I experience disconnections to the internet, 2-3 times a day. The Genexis shows that it...
CrimpOn
Sep 29, 2019Guru - Experienced User
The next time this happens, can you go to the Orbi web interface, the Advanced Tab, and click on the "Connection Status".
What does it show for the DHCP lease? Here's mine:
- ydesSep 29, 2019Aspirant
Hi
the values I have now are the following, and if I remeber correctly, I see similar ones when the issue occures (maybe the exipration is a bit higher, like 26 min):
Lease Obtained 0 Days, 0 Hours, 30 Minutes Lease Expires 0 Days, 0 Hours, 22 Minutes
- CrimpOnSep 29, 2019Guru - Experienced UserA 30 minute DHCP lease is VERY short. I would call the provider and ask, "WFT?"
- ydesSep 30, 2019Aspirant
Hello,
I asked them and they say it is normal.
Their exact answer is "The lease lasts for 30mins and is refreshed every 15minutes. This is normal"
Does that affect my router that much?
